Setting the File Format
You can set the file format to use when scanning originals.
Press [Scan and Send] → specify the destination → press the file format button.
Select a file format for the image to send.
[JPEG]:
Sends the file in the JPEG format, if you select a color mode other than Black-and-White.
[TIFF]:
Sends the file in the TIFF format, if you select a color mode other than Black-and-White.
[PDF]:
Sends the file in the PDF file format, regardless of the color mode. You can also specify additional settings.
[XPS]:
Sends the file in the XPS file format, regardless of the color mode. You can also specify additional settings.
[OOXML]:
Sends the file in the Office Open XML (pptx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If you send the file stored in the Mail Box or Memory RX Inbox, you cannot select OOXML as the file format.
If you select [JPEG]:
If you select [TIFF], [PDF], [XPS], or [OOXML]:
Press [OK].
If you select [JPEG], [Divide into Pages] is set to 'On'.
Specify whether or not to divide your files into separate pages → press [OK].
If you want to separate multiple images and save them as separate files, set [Divide into Pages] to 'On'. If you want to store the images as a single file, set the setting to 'Off'.
You can select additional settings if you send in the PDF, XPS or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]: Trace and Smooth
[OCR (Text Searchable)]: Searchable PDF/XPS/OOXML
[Apply Policy]: Applying a Policy
To set the resolution to 200 x 400 dpi, 400 x 400 dpi, or 600 x 600 dpi when the file format is set to [JPEG], it is necessary to install the Additional Memory Type A (512MB) to expand the memory capacity of the machine.
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view a TIFF file, software that supports the TIFF format (such as Imaging for Windows) is required.
To view a PDF file or to search a text in a PDF file, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view an XPS file or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
To view an OOXML file or to search a text in an OOXML file, software that supports the OOXML format (such as Microsoft PowerPoint 2007/2010) is required.
» Scan and Send » Setting the File Format
0CYL-109
