To receive documents in memory, you must first set [Use Fax Memory Lock] or [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store received documents in memory in the cases below. These numbers may vary depending on the remaining capacity of the hard disk.
When a total of 2,000 documents or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 20,000 pages of documents or images are stored in the Mail Box and Fax/I-Fax Inbox
