Memory RX Inbox
The Memory RX (Receive) Inbox is an inbox for storing files received by Fax and I-Fax. Files received by the Memory RX Inbox are stored without being printed. You can print or send the stored files whenever necessary.
If you want to use Memory Lock, you must first set [Use Fax Memory Lock] and [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store any more files in the Fax/I-Fax Inbox in the cases described below. These numbers may vary depending on the remaining capacity of the hard disk.
When a total of 2,000 files or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 20,000 pages of files or images are stored in the Mail Box and Fax/I-Fax Inbox
If a message prompting you to enter the PIN appears, enter the number registered in [Memory RX Inbox PIN]. (See "Specifying the Fax/I-Fax Inbox Settings.")
» Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox
0CYL-16S
