You cannot register new destinations in a group destination that is stored in a one-touch button. The destinations must be registered in the one-touch buttons beforehand.
Storing/Editing One-Touch Buttons
Press [Fax] →  (Register One-Touch Button).
Select a one-touch button to store or edit → press [Register/Edit].
If you know the three digit number for the one-touch button, you can press  → enter the three digit number of the desired one-touch button using - (numeric keys).
If you select a one-touch button in which a destination is already stored, proceed to step 3.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
(Fax)
(Group)
Select the type of destination to register.
If you select [Fax]:
If you select [Group]:
If you select [LDAP Server]:
Press [Fax].
Enter a name for the address in [Name] in accordance with steps 5 and 6 of "Storing Fax Numbers."
Press [One-Touch Name].
Enter a name → press [OK].
Enter the fax number in accordance with step 8 and 9 of "Storing Fax Numbers."
Press [Group].
Enter a name for the group destination in [Name] in accordance with steps 5 and 6 of "Storing Group Addresses."
Select a destination to store in the group address from [Add from One-Touch] → press [OK].
You can only select destinations that are already stored in one-touch buttons to be part of a one-touch button group address.
Press [LDAP Server].
Specify the address by using LDAP server in accordance with steps 4 to 9 of "Specifying Destinations Using the Address Book (LDAP Server)."
Select the destination from the search results → press [Next].
You cannot select multiple destinations at the same time.
To cancel a specified destination, select the destination you want to register again.
If necessary, edit the contents of the destination.
The information that you can obtain via the LDAP server consists of only names and fax numbers.
Press [OK].
4.
Press [Close] → [OK].
Deleting One-Touch Buttons
Select the one-touch button to delete → press [Delete].
If you know the three digit number for the desired one-touch button, you can press  → enter the three digit number of the desired one-touch button using - (numeric keys).
(Fax)
(Group)
Press [Yes].
4.
Press [Close].
If you set [Language/Keyboard Switch On/Off] to 'On', the host name and folder path of the file server destination may not appear correctly, and you may not be able to browse them. (See "Enabling the Language/Keyboard Switch.")
Destinations stored in one-touch buttons also appear in the Local Address Book.
» Fax » Sending/Receiving a Fax » Storing New Addresses » Storing/Editing/Deleting One-Touch Buttons
0CYL-0S8
