Changing the Default Settings for the Fax Function
You can change the default settings for [Fax].
This mode can be set when the Fax function is available for use. For information on the optional products required to use the Fax function, see "Optional Products Required for Each Function."
To register a favorite settings button, set the Fax mode in advance.
Press [Function Settings] → [Send] → [Fax Settings].
Press [Change Default Settings].
4.
Press [Register].
5.
Press [Yes].
6.
Press [Close].
Initializing the Default Settings for the Fax Function
4.
Press [Initialize].
5.
Press [Yes].
» Settings/Registration » Function Settings » Send » Specifying the Fax Settings » Changing the Default Settings for the Fax Function
0CYL-0A7
