Changing the Default Settings for Send
You can change the default settings for [Scan and Send].
To register changes to the default settings, you must specify the Send settings in advance.
Press [Function Settings] → [Send] → [Common Settings].
Press [Change Default Settings].
4.
Press [Register].
The current Send settings are set as the default settings.
5.
Press [Yes].
6.
Press [Close].
Initializing the Default Settings for Send
4.
Press [Initialize].
5.
Press [Yes].
» Settings/Registration » Function Settings » Send » Common Settings » Changing the Default Settings for Send
0CYL-091
