Function Settings: Copy
The Copy function appears only when the appropriate optional product is available for use.
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Register/Edit Favorite Settings]
M1 to M9: Register, Rename, Delete, Check Content
No
No
[Change Default Settings]
Register, Initialize
No
No
[Register Options Shortcuts]
Shortcut 1: Each mode, Unassigned
Finishing
No
No
Shortcut 2: Each mode, Unassigned
2-Sided
No
No
Shortcut 3: Each mode, Unassigned
Density
No
No
Shortcut 4: Each mode, Unassigned
Original Type
No
No
Shortcut 5: Each mode, Unassigned
Unassigned
No
No
[Register Options Shortcuts] (Express Copy)
Shortcut 1 to 6: Each mode, Unassigned
Unassigned
No
No
[Auto Collate]
On, Off
On
No
Yes
[Auto Orientation]
On, Off
On
No
Yes
[Photo Printout Mode]
On, Off
Off
No
Yes
[Register Remote Device for Cascade Copy]
Register (Up to seven printers), Details, Delete
Yes
No
[Cascade Copy Communication Timeout]
5 to 30 seconds
30 seconds
No
Yes
» Settings/Registration » Settings/Registration Table » Function Settings » Function Settings: Copy
0CYL-04L
