Adjustment/Maintenance
Adjustment/Maintenance: Adjust Image Quality
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Auto Adjust Gradation]
Paper Select, Start Printing key
No
No
[Correct Density]
Black & White Scan for Copy/Scan and Store (Mail Box), Black & White Scan for Send/Scan and Store (Other Than Mail Box), Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
Adjustment/Maintenance: Adjust Action
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Saddle Stitcher Staple Repositioning]*1
Start key
No
No
[Change Fold/Stitch Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
0.00 mm
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Adjustment/Maintenance: Maintenance
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Clean Feeder]*1
Start key
No
No
*1 If you are using the imageRUNNER ADVANCE 4235/4225, this item appears only when the appropriate optional product is available for use.
» Settings/Registration » Settings/Registration Table » Adjustment/Maintenance
0CYL-04J
