[Book Type]:
The front and back sides of the print will have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the print will have opposite top-bottom orientations.
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
You may not be able to print, depending on the paper type.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: 11" x 17", LGL, LTR, LTRR, EXEC, STMTR
Paper weight: 16 to 28 lb bond (60 to 105 g/m2)
If there are an odd number of pages in the file, the back side of the last print is left blank. (The machine's counter does not count the blank page as a print.)
