Function
Functions Unavailable for Combination
Automatic Paper Selection
Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Automatic Paper Selection, Multi-Purpose Tray*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Different Size Originals
Paper Drawer Auto Selection
Multi-Purpose Tray
Automatic Paper Selection*1, Automatic Paper Selection
(Auto Orientation)*1, Collate*1, Group*1, Rotate 90 Degrees: Collate*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Staple*1, Saddle Stitch*1, Offset*1, Hole Punch*1, 2-Sided Printing*1, Document Separate Duplex Printing*1, Document Separate Continuous Printing*1, Front Cover*1, Back Cover*1, Sheet Insertion*1, Chapter Page*1, Job Separator*1, Booklet*1, Saddle Stitch (Booklet)*1, Front Cover (Booklet)*1, Divided Booklet*1, Creep Correction (Booklet)*1, Saddle Fold (Booklet)*1, Page Numbering (with Free Size or Transparency selected), Copy Set Numbering (with Free Size or Transparency selected), Watermark/Print Date (with Free Size or Transparency selected), Shift*2, Secure Watermark*2, Secure Watermark (Copy Set Numbering)*2
Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper)
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Saddle Stitch, 2-Sided Printing, Front Cover*3, Back Cover*3, Sheet Insertion*3, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Collate
Multi-Purpose Tray*1, Group*4, Rotate 90 Degrees: Collate*4, Rotate 90 Degrees: Group*4, Offset Collate*4, Staple*4, Saddle Stitch*4, Offset*4, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Group
Multi-Purpose Tray*1, Collate*4, Rotate 90 Degrees: Collate*4, Rotate 90 Degrees: Group*4, Offset Collate*4, Staple*4, Saddle Stitch*4, Offset*4, Document Separate Duplex Printing, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion, Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Sample Print*4, Merge Files and Print, Copy Set Numbering, Secure Watermark (Copy Set Numbering)
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*1, Collate*4, Group*4, Rotate 90 Degrees: Group*4, Offset Collate, Staple, Saddle Stitch, Offset, Hole Punch, Front Cover, Back Cover, Sheet Insertion, Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*1, Collate*4, Group*4, Rotate 90 Degrees: Collate*4, Offset Collate, Staple, Saddle Stitch, Offset, Hole Punch, Front Cover, Back Cover, Sheet Insertion, Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Sample Print*4, Secure Watermark (Copy Set Numbering)
Offset Collate
Multi-Purpose Tray*1, Collate*4, Group*4, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Staple*4, Saddle Stitch*4, Offset*4, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Staple
Multi-Purpose Tray*1, Collate*4, Group*4, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Saddle Stitch*4, Offset, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Saddle Stitch
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*1, Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper), Collate*4, Group*4, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Staple*4, Offset, Hole Punch, 1-Sided Printing, Front Cover, Back Cover, Sheet Insertion, Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Sample Print, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark/Print Date, Superimpose Image, Secure Watermark (Copy Set Numbering)
Offset
Multi-Purpose Tray*1, Collate*4, Group*4, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Staple*4, Saddle Stitch*4, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Hole Punch
Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
1-Sided Printing
Saddle Stitch, 2-Sided Printing*4, Document Separate Duplex Printing*4, Document Separate Continuous Printing*4
2-Sided Printing
Multi-Purpose Tray*1, Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper), 1-Sided Printing*4, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Multi-Purpose Tray*1, Group, 1-Sided Printing*4, Document Separate Continuous Printing*4, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Single Document, Multiple Documents
Multi-Purpose Tray*1, Group, 1-Sided Printing*4, Document Separate Duplex Printing*4, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Single Document, Multiple Documents
Front Cover
Multi-Purpose Tray*1, Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper)*3, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Saddle Stitch, Document Separate Duplex Printing, Document Separate Continuous Printing, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Multiple Documents, Superimpose Image
Back Cover
Multi-Purpose Tray*1, Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper)*3, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Saddle Stitch, Document Separate Duplex Printing, Document Separate Continuous Printing, Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Multiple Documents, Superimpose Image
Chapter Page
Multi-Purpose Tray*1, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Saddle Stitch, Document Separate Duplex Printing, Document Separate Continuous Printing, Sheet Insertion (Print/Leave Blank), Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Multiple Documents, Superimpose Image
Job Separator
Multi-Purpose Tray*1, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Saddle Stitch, Document Separate Continuous Printing, Sheet Insertion (Print/Leave Blank), Chapter Page, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Single Document, Multiple Documents, Superimpose Image
Booklet
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*1, Multi-Purpose Tray (Printing on the Reverse Side of Preprinted Paper), Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group*4, Offset Collate, Staple, Saddle Stitch, Offset, Hole Punch, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Job Separator, Different Size Originals, Multiple Documents*5, Watermark/Print Date, Superimpose Image, Gutter, Shift, Secure Watermark, Secure Watermark (Copy Set Numbering)
Divided Booklet
Automatic Paper Selection (Auto Orientation), Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet)
Single Document
Document Separate Duplex Printing, Document Separate Continuous Printing, Job Separator, Multiple Documents, Merge Files and Print
Multiple Documents
Document Separate Duplex Printing, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Job Separator, Booklet*5, Saddle Stitch (Booklet)*5, Front Cover (Booklet)*5, Divided Booklet*5, Creep Correction (Booklet) *5, Saddle Fold (Booklet)*5, Sample Print, Single Document, Merge Files and Print
Group, Single Document, Multiple Documents
Page Numbering
Multi-Purpose Tray (Free Size, Transparency), Superimpose Image, Shift, Secure Watermark, Secure Watermark (Copy Set Numbering)
Copy Set Numbering
Multi-Purpose Tray (Free Size, Transparency), Group, Saddle Stitch, Superimpose Image, Shift, Secure Watermark, Secure Watermark (Copy Set Numbering)
Multi-Purpose Tray (Free Size, Transparency), Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Superimpose Image, Shift, Secure Watermark, Secure Watermark (Copy Set Numbering)
Superimpose Image
Saddle Stitch, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Job Separator, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Page Numbering, Copy Set Numbering, Watermark/Print Date, Secure Watermark, Secure Watermark (Copy Set Numbering)
Gutter
Shift
Multi-Purpose Tray*2, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Page Numbering, Copy Set Numbering, Watermark/Print Date, Secure Watermark (Copy Set Numbering)
Secure Watermark
Multi-Purpose Tray*2, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Page Numbering, Copy Set Numbering, Watermark/Print Date, Superimpose Image, Secure Watermark (Copy Set Numbering)*4
Multi-Purpose Tray*2, Group, Rotate 90 Degrees: Group, Saddle Stitch, Booklet, Saddle Stitch (Booklet), Front Cover (Booklet), Divided Booklet, Creep Correction (Booklet), Saddle Fold (Booklet), Page Numbering, Copy Set Numbering, Watermark/Print Date, Superimpose Image, Shift, Secure Watermark*4
Function
Multi-Purpose Tray, Staple*1, Hole Punch*1, Match Paper Size, N on 1, Booklet
Multi-Purpose Tray
Automatic Paper Selection, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Staple*1, Hole Punch*1, 2-Sided Printing, Booklet
Collate
Multi-Purpose Tray, Group*2, Rotate 90 Degrees: Collate*2, Rotate 90 Degrees: Group*2, Offset Collate*2, Offset Group*2, Staple*2, Booklet
Group
Multi-Purpose Tray, Collate*2, Rotate 90 Degrees: Collate*2, Rotate 90 Degrees: Group*2, Offset Collate*2, Offset Group*2, Staple*2, Booklet
Automatic Paper Selection, Multi-Purpose Tray, Collate*2, Group*2, Offset Collate, Offset Group, Staple, Hole Punch, Booklet
Automatic Paper Selection, Multi-Purpose Tray, Collate*2, Group*2, Rotate 90 Degrees: Collate*2, Offset Collate, Offset Group, Staple, Hole Punch, Booklet
Offset Collate
Collate*2, Group*2, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group*2, Staple*2, Booklet
Offset Group
Collate*2, Group*2, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Staple*2, Booklet
Staple
Automatic Paper Selection*1, Multi-Purpose Tray*1, Collate*2, Group*2, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Booklet
Hole Punch
Automatic Paper Selection*1, Multi-Purpose Tray*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Booklet
2-Sided Printing
Multi-Purpose Tray, Booklet
Match Paper Size
Automatic Paper Selection, N on 1*3, Booklet*3
N on 1
Automatic Paper Selection, Match Paper Size*3
Booklet
Automatic Paper Selection, Multi-Purpose Tray, Collate*2, Group*2, Rotate 90 Degrees: Collate*2, Rotate 90 Degrees: Group*2, Offset Collate*2, Offset Group*2, Staple*2, Hole Punch*2, 2-Sided Printing, Match Paper Size*3
Function
Standard Size Paper Selection
Multi-Purpose Tray
Multi-Purpose Tray
Standard Size Paper Selection, 2-Sided Printing
2-Sided Printing
Multi-Purpose Tray
