» Web Access » Using Favorites » Organizing Favorites
You can change the names of Web pages registered in Favorites, as well as delete those Web pages that are no longer necessary.
Press [Web Access].
Press [Favorites].
Press [Organize Favorites].
4.
Organize Favorites.
Press [Name] or [Order] to sort the Favorites list in ascending or descending order.
The icons on the Main Menu screen are deleted/renamed when you delete/rename the corresponding Web pages.
If you want to confirm the information of a Web page registered in Favorites:
If you want to change the name of a Web page:
If you want to erase a registered Web page from Favorites:
If you want to erase all of the Web pages registered in Favorites:
Select the desired Web page → press [Details].
The detailed information of the selected Web page is displayed.
Press [OK].
Select the desired Web page → press [Edit].
Press the <Name> text entry field.
Enter a new name → press [OK].
If you press [OK] without entering a name in the name field, the URL address is registered as the name.
Select the desired Web page → press [Delete].
Press [Yes].
Press [Delete All].
Press [Yes].
