(Settings/Registration).|
[By WebDAV]:
The Advanced Box is opened externally as a WebDAV server.
[By SMB]:
The Advanced Box is opened externally as an SMB server.
The Advanced Box cannot be opened externally as a WebDAV server and SMB server at the same time.
To open the Advanced Box externally by SMB, it is necessary to set [Use SMB Server] to 'On' in [Preferences] (Settings/Registration). (See "SMB and WINS Settings.")
To open the Advanced Box externally by WebDAV, it is necessary to set [Use WebDAV Server] to 'On' in [Preferences] (Settings/Registration). (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
For more information on authentication management, see "User Access Control for Advanced Box."
To use authentication management, it is necessary to set <Use SMB Authentication> in [SMB Auth. Settings] in [Preferences] (Settings/Registration) to 'On', and set the authentication type. (See "SMB and WINS Settings.")
To use authentication management, it is necessary to set the authentication type (Basic) in [WebDAV Server Settings].
[On]:
SSL communication is used.
[Off]:
SSL communication is not used.
To set <Use SSL> to 'On', it is necessary to first set the key pair and server certificate (see "Key Pair and Server Certificate Settings for Encrypted SSL Communication") and then set the key as the default key (see "Setting the Key Pair Used With SSL Encrypted Communications").
If you want to allow personal spaces to be created, make sure you use authentication management.
To select and delete a personal space that a user has created, use the Remote UI. For more information, see "Specifying the Advanced Box Settings."
If the Advanced Box is opened externally as an SMB or WebDAV server, the Advanced Box administrator can delete the folders and files created by general users by directly connecting to the Advanced Box from Windows Explorer on a computer.
To select and delete a folder inside the shared space, use the Remote UI. For more information, see "Specifying the Advanced Box Settings."
To send to the Advanced Box of a machine from the same machine, it is recommended that you specify a loopback address (an address that indicates the machine on a network). You can store files sent from a loopback address even if [Prohibit Writing from External] is set to 'On'. For instructions on registering an Advanced Box folder as a destination in the Address Book, see "Registering an Advanced Box Address."
Even if [Prohibit Writing from External] is set to 'On' for an Advanced Box that is opened externally, the Advanced Box administrator can perform the following operations:
Operate folders/edit files by directly connecting to the Advanced Box from Windows Explorer on a computer.
Operate folders/edit files from [Network] in [Scan and Store] or [Access Stored Files] on the touch panel display.
[Printable Formats Only]:
You can store files in pdf, jpg, jpe, jpeg, tif, or tiff format.
[Comm. Office Formats]:
In addition to the file formats for [Printable Formats Only], you can store files in doc, xps, docx, docm, rtf, xls, xlsx, xlsm, csv, ppt, pptx, pptm, txt, iwd, iwt, iws, or lnk format.
[All]:
There are no restrictions on the file formats for storing in the Advanced Box. In addition to the file formats for [Printable Formats Only] and [Comm. Office Formats], you can store files in various formats.
