You can return device information only to what it was at the time of the very last update.
While receiving and updating device information, the screen indicating that the settings are being updated appears. Operations on this machine cannot be performed until the update completes.
(Settings/Registration).
You cannot restore the settings of Workflow Composer to what they were before the device information was updated.
If you do not restore data for [Settings/Reg. Value] and [Address Book] at the same time, the settings in [URL Send Settings] for [Set Fax/I-Fax Inbox] and [Mail Box Settings] may be erased.
(Settings/Registration). |
Before setting <Settings/Reg. Value>, <Dept. ID>, or <Address Book> to 'Off', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
