(Status Monitor/Cancel), the Status Monitor/Cancel screen appears, enabling you to check and change the status of Copy/Print, Send, Receive and Store jobs.|
Icon (Job Status)
Description
Executing
Waiting
Interrupt/Priority Printing
Error
Canceling
Paused/Need Paper
Secured Print
Encrypted Secured Print*
Sent
This icon appears only when the appropriate optional products are available for use. For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Icon (Job Type)
Description
Copy Job
Print Job
Send/Fax Job
Mail Box Job
Advanced Box Job
Network Job
Memory Media Job
Report Print Job
The most recent 100 copy or print jobs, and a combined total of the 100 most recent send and receive jobs are displayed in the log.
If [Display Log] in [Management Settings] (Settings/Registration) is set to 'Off', [Log] for each screen is not displayed.
If Department ID Management or a login service (such as SSO-H) is set and [Display Job Status Before Authentication] is set to 'Off', operations other than displaying the Device Status screen cannot be performed even when you press
(Status Monitor/Cancel), unless you have logged in to the machine. (See "Setting the Control Panel Display.")Many of the check/change operations can also be performed from the Remote UI. (See "Managing Jobs.")
The status bars on the keys for selecting a job type, flash in blue or orange to indicate the status of jobs. The status bars flash blue when there are current jobs that are being processed, and maintain a steady blue light when there are jobs in the print queue. Flashing orange status bars indicate errors. For instructions on resolving errors, see "List of Error Messages."
The Fax function is available only if the optional product is installed. For information on the optional product required to use this function, see "Optional Products Required for Each Function."
