Press to restore the previous settings and close the screen.
Press to return to the setting before the current settings screen was displayed, and close the screen.
Press to confirm one setting and proceed to the next settings screen.
Press to return to the previous settings screen.
Press to close the current screen.
Press to confirm the setting and close the screen.
State of Keys
Description
The 2-Sided mode is not set, and can be selected.
![]() (The key is highlighted)
The 2-Sided mode is set, and can be selected.
![]() (The characters on the key are grayed out.)
You cannot select the 2-Sided mode in combination with the presently set mode.
Mode Is Disabled
Mode Is Enabled
![]() (Checked)
![]() (Highlighted)
) indicate that those keys have additional screens to set their functions. If you press a key that does not have a right triangle (
), it turns that mode ON or OFF.|
Keys That Display Additional Settings
Keys That Turn Modes ON/OFF
Settings Are Stored
No Settings Are Stored
) to the right of its name, displays a drop-down list containing other setting options.|
Before Selection
Drop-Down List
After Selection
You can enter values using the numeric keys on the touch panel display or on the control panel.
You can only enter values using the numeric keys on the control panel.
appears on the touch panel display, you can check a detailed explanation of the function and its settings.
