on the top right of the screen is used.|
1
The name of the function that is currently being used is displayed.
2
Presently stored function shortcut buttons are displayed.
3
The shortcut buttons for the modes you registered from [Register Options Shortcuts] are displayed.
4
If you are logged in using a login service, [Log Out] is displayed.
5
An icon indicating that a paper or staple jam has occurred, or an icon indicating that a USB device is attached, is displayed here.
6
The progress of jobs and copy operations, and the status of devices and consumables are displayed here. Also, depending on the login service you are using, the Department ID or user name can be displayed.
For information on the screens that can be set to display after the machine starts up, see "Default Screen at Startup."
The settings that can be specified may differ, depending on the user's privileges.
For more information on registering and editing Favorite Settings, see the following:
Registering/Editing/Deleting Favorite Settings Buttons for Scan and Send
Registering and Editing Favorite Settings for Access Stored Files
Registering and Editing Favorite Settings for Scan and Store
For more information on the Register Options Shortcuts settings, see the following:
Registering Shortcut Keys for Copy
Registering Shortcut Keys for Scan and Send
Registering Shortcut Keys for Fax Settings
[Set SMTP Authentication] appears only on the function screen for [Scan and Send]. For more information on SMTP authentication settings, see "Applying SMTP Authentication for Each User."
