e-ManualTopSite mapHelp
Top » Remote UI » Managing Jobs
Managing Jobs
0UKW-0X1
The Remote UI provides you with job management capabilities, which enable you to check job status, and pause/resume jobs.
The types of jobs that can be managed are:
Print jobs for the Print functions
If you set [Display Log] to 'Off', [Job Log] is not displayed.
Depending on the number of entries in the log, the log may take some time to be displayed.
You cannot use the Remote UI to check the job status of or pause/resume encrypted secured print jobs.
The job management operations available using the Remote UI are the same as those that you can access from [Status Monitor/Cancel] on the touch panel display of the machine. For instructions on using the control panel, see "Basic Operations."
For more information on job management, see "Basic Operations."
