Checking the Status of Consumables and Other Information
You can check the status of consumables, such as detailed paper information and the remaining amount of toner and staples. You can also register/set the paper type to load in a paper drawer.
Press [Status Monitor/Cancel].
Press [Consumables].
To check the details of paper loaded in the machine:
To check other information:
To register/set a paper type:
Select the paper you want to check → press [Details].
You can press  to enlarge the displayed list.
Press [OK].
Check the percentage of memory usage, amount of waste toner, and the remaining amounts of toner and staples.
The table below indicates the remaining amount of consumables.
Display
Remaining amount of toner
OK
100% to 11%
Low
10% to 1%
Empty
0%
Display
Amount of waste toner
OK
0% to 97%
Near Full
98% to 99%
Full
100%
Display
Remaining amount of staples
OK
100% to 1%
Empty
0%
Press [Reg.].
Select an item to register/set → register/set the paper type.
[Paper Settings]:
Sets the paper type to load by selecting a paper source.
[Paper Type Management Settings]:
Registers a user-defined paper type by entering a name.
For instructions on specifying [Paper Settings], see "Registering the Paper Size and Type for a Paper Source."
For instructions on specifying [Paper Type Management Settings], see "Registering/Editing Custom Paper Types."
Press [OK].
» Status Monitor/Cancel » Checking the Status of Consumables and Other Information
0C1Y-14J
