Function Settings: Printer
The following table lists all settings of the Printer Settings menu.
Output Report
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
PCL
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
Common Settings (Printer Settings > Custom Settings)
Item
Setting Description
Default Setting
Can be set in
Remote UI
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
Letter, Legal, A4, B5, A5, Executive, Statement, Env. NAGAGATA 3, Env. YOGATANAGA3, Envelope Monarch, Env. No. 10, Envelope ISO-C5, Envelope DL
Letter
Yes
No
[Default Paper Type]
Plain 1, Plain 2, Recycled, Color, Pre-Punched, Bond, Heavy 1, Heavy 2, Transparency, Labels, Envelope
Plain 2
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Print Quality]
[Image Refinement]
On, Off
On
Yes
Yes
[Density]*1
-8 to +8
0
Yes
Yes
[Density (Fine Adjust)]*1
High: -8 to +8
Medium: -8 to +8
Low: -8 to +8
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Line Refinement]
On, Off
Off
Yes
Yes
[Horizontal Line Refinement]
Off, Level 1, Level 2,Level 3, Level 4
Off
Yes
Yes
[Vertical Line Refinement]
Level 1
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-50.0 mm to +50.0 mm
0.0
Yes
Yes
[Offset Short Edge (Front)]
0.0
Yes
Yes
[Offset Long Edge (Front)]
0.0
Yes
Yes
[Offset Short Edge (Back)]
0.0
Yes
Yes
[Offset Long Edge (Back)]
0.0
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
Off, Collate, Offset+Collate*1,Offset+Group*1, Staple+Collate*1, Staple+Group*1
Staple Position (Staple+Collate):
Corner (Upper-L),Corner (Upper-R),Corner (Lower-R),Corner (Lower-L)
Staple Position (Staple+Group):
Grp Upp L-Corner,Grp Upp R-Corner,Grp Lwr R-Corner,Grp Lwr L-Corner
Off
Yes
Yes
[Copy Set Numbering]
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
Small(12 point), Medium(24 point), Large(36 point)
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF, XPS
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.")
None, PS, PCL, PDF, XPS
None
Yes
No
[Initialize]
Yes, No
No
Yes
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
UFR II Settings (Printer Settings > Custom Settings > UFR II)
Item
Setting Description
Default Setting
[Halftones]
Text: Color Tone, Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Color Tone, Gradation, Resolution, High Resolution
Color Tone
Image: Color Tone, Gradation, Resolution, High Resolution
Color Tone
[Paper Save]
On, Off
On
Yes
Yes
PCL Settings (Printer Settings > Custom Settings > PCL)
Item
Setting Description
Default Setting
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
60 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
5.50 to 24.80 inches
14.00 inches
Yes
No
[Y dimension]*1
3.89 to 8.50 inches
8.50 inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Color Tone
Color Tone
[BarDIMM]
Enable, Disable
Disable
Yes
Yes
[FreeScape]*1
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
PS Settings (Printer Settings > Custom Settings > PS)
Item
Setting Description
Default Setting
[Job Timeout]
0 to 3600 seconds
0
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Halftones]
Text: Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Gradation, Resolution, High Resolution
Resolution
Image: Gradation, Resolution, High Resolution
Resolution
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
[Dot Gain Adjustment]
-10%, -5%, Standard, +5%, +10%
Standard
Yes
Yes
*1
Imaging Settings (Printer Settings > Custom Settings > Imaging) *2
Item
Setting Description
Default Setting
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Halftones]
Gradation
Yes
Yes
NTSC
Yes
Yes
*1
*2
Indicates items that appear only when using a Direct Print Printer.
PDF Settings (Printer Settings > Custom Settings > PDF) *2
Item
Setting Description
Default Setting
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
NTSC
Yes
Yes
Standard
Yes
Yes
*1
*2
XPS Settings (Printer Settings > Custom Settings > XPS) *2
Item
Setting Description
Default Setting
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
Text: sRGB, NTSC, Uniform RGB
sRGB
Yes
Yes
Graphics: sRGB, NTSC, Uniform RGB
sRGB
Image: sRGB, NTSC, Uniform RGB
sRGB
*1
*2
Utility Settings (Printer Settings > Utility)
Item
Setting Description
Default Setting
[Initialize PCL Hard Disk]
Yes, No
No
No
[Initialize PS Hard Disk]
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
Printer Menu
Item
Setting Description
Default Setting
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
[PDL Selection (Plug-n-Play)]
UFR II, PS3, UFR II (XPS), Fax, PCL5e, PCL6
UFR II
Yes
No
» Settings/Registration » Settings/Registration Table » Function Settings » Function Settings: Printer
0C1Y-04L
