Auto Error Skip
[On], [Off]*
This setting enables you to automatically clear an error and continue printing when an error occurs (Skip Error).
[On]
[Skip Error] is performed automatically.
[Off]
You must perform [Skip Error] from the touch panel display.
To perform [Skip Error], press [Job Status] on the Status Monitor/Cancel screen → select the job containing the error → press [Details] → [Skip Error].
[Skip Error] only temporarily clears an error, so the data may not print correctly.
For information on types of errors that can be temporarily cleared with Auto Error Skip, see "Printer."
This setting is valid even if multiple errors have occurred.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Auto Error Skip
0C1Y-17L
