Selecting a Profile for Faxing
You can apply registered fax settings by simply selecting an item from [Profile] list.
Select [Print] from the [File] menu of the application.
Select your fax from [Name] → click [Properties].
Select a profile from the [Profiles] list according to your objective.
You can select a profile in the [Sending Settings], [Cover Sheet], or [Special] tab.
4.
Click [OK].
For information on registering a profile, see "Registering a Profile for Faxing."
Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
The display may vary according to the operating system and system environment.
» Fax » Sending a Fax from a Computer (Windows) » Selecting a Profile for Faxing
08KY-0WK
