Cause 1
Printing cannot be performed because the paper has run out.
Remedy
Load paper. (See "Loading Paper.")
Cause 2
The paper drawer is not correctly inserted into the machine.
Remedy
Insert the paper drawer in all the way. (See "Loading Paper.")
Cause 1
The optimal paper size selected with automatic paper selection is not loaded.
Remedy
Load paper of the displayed size.
Cause 2
[Paper Drawer Auto Selection On/Off] is set to 'Off'.
Remedy 1
Manually specify the paper drawer.
Remedy 2
Set [Paper Drawer Auto Selection On/Off] to 'On' for the paper drawer in which the displayed paper size is loaded. (See "Enabling Paper Drawer Auto Selection.")
Cause 3
A paper type not supported by automatic paper selection is loaded.
Remedy 1
Remedy 2
Set [Consider Paper Type] in [Paper Drawer Auto Selection On/Off] to 'Off' when copying. (See "Enabling Paper Drawer Auto Selection.")
Cause
Scanning stopped because an unspecified problem occurred in the feeder.
Remedy
Return the originals to their correct order, place them in the original loading area of the feeder again, and press
(Start). |
Return the originals to their correct order, then press the [Start] key. (The data size of the scanned original exceeded the limit. Settings will be automatically corrected and the originals will be scanned again.)|
Cause
Scanning was canceled because the data size of the scanned originals exceeded the maximum size that the machine can handle.
Remedy
Scan the originals again from the first page. If you still cannot scan the originals, you may be able to resolve the problem by decreasing the setting for [Sharpness] or setting the original type to [Text].
Scanning was canceled because the data size of the scanned original exceeded the limit. Scanning may be possible if sharpness is reduced, or Original Type is set to Text.|
Cause
Remedy
You may be able to resolve the problem by decreasing the setting for [Sharpness] or setting the original type to [Text].
Cause
A mode requiring an original to be placed on the platen glass is set. There is no original on the platen glass.
Remedy
Place the original on the platen glass.
Cause
An original remains on the platen glass.
Remedy
Remove the original remaining on the platen glass, and place the original again.
Cause
There is an original loaded in the feeder and on the platen glass when a mode that cannot scan originals loaded in the feeder is set.
Remedy
Remove the original from the feeder.
Cause
The original scanning area (thin glass strip) is dirty due to dust and grime.
Remedy
Clean the original scanning area of the feeder. (See "Manual Feeder Cleaning.")
Cause
The original scanning area of the Duplex Color Image Reader Unit-G1 is dirty due to dust and grime.
Remedy
Clean the original scanning area of the Duplex Color Image Reader Unit-G1. (See "Manual Feeder Cleaning.")
Cause 1
Printing will soon not be possible because the toner is running out.
Cause 2
Printing is not possible because the toner has run out.
Remedy
Replace the toner cartridge. (See "Replacing the Toner Cartridge.")
Cause
The machine is performing automatic adjustment.
Remedy
Wait a few moments. When the adjustment is complete, printing will automatically resume.
Cause
The machine is cleaning its drum.
Remedy
Wait a few moments. When cleaning is complete, printing will automatically resume.
Cause
Multiple jobs such as print jobs or scan jobs are being executed while performing the scan operation.
Remedy
Wait a few moments for the machine to resume the scan operation.
Cause
Output from a previous job remains in the output area of the Document Insertion/Folding Unit-H1.
Remedy
Remove the paper in the output area of the Document Insertion/Folding Unit-H1.
Cause
The cover of an optional equipment is open.
Remedy 1
Check that the cover of the Paper Deck Unit-A1 or Paper Deck Unit-D1 is closed.
Remedy 2
Check that the cover of the Document Insertion Unit-L1, External 2/3 Hole Puncher-A1, Document Insertion/Folding Unit-H1, Staple Finisher-P1, or Booklet Finisher-P1 is closed.
Cause
There are no staples in the staple cartridge of the stapler unit in the Staple Finisher-P1/Booklet Finisher-P1.
Remedy
Replace the staple cartridge of the Staple Finisher-P1/Booklet Finisher-P1. (See "Replacing the Staple Cartridge (For Optional Products).")
Cause
Previous prints remain in the tray.
Remedy
Remove the paper that remains in the tray. Printing will start or resume automatically.
Cause
Remedy
Remove the paper that remains in the booklet tray. Printing will start or resume automatically.
Cause
The punch waste tray of the External 2/3 Hole Puncher-A1 is full or almost full.
Remedy
Remove the punch waste in the punch waste tray of the External 2/3 Hole Puncher-A1. (See "Removing Punch Waste (External 2/3 Hole Puncher-A1).")
Cause
There are no staples in the staple cartridge of the Booklet Finisher-P1 saddle stitcher unit.
Remedy
Replace the staple cartridge of the Booklet Finisher-P1 saddle stitcher unit. (See "Replacing the Staple Case in the Saddle Stitcher Unit (Booklet Finisher-P1).")
Cause
The entered Department ID or PIN is incorrect.
Remedy
Contact the System Manager for the department to find out the Department ID/PIN.
Cause
The hard disk is damaged or is not attached.
Remedy 1
Contact your local authorized Canon dealer.
Remedy 2
If the Removable HDD Kit is attached, check the hard disk.
