Set the receive mode to one of the following.
<Fax/Tel Auto Switch>
<Auto>
<Answering Machine>
"RX Mode"
When <Answering Machine> is set, make sure that an external telephone with the built-in answer function is connected to the machine. Also make sure that it is always turned on and the recorded answering message can be heard anytime.
Print, send, or delete jobs stored in memory.
See the following section:
Make sure the machine is set to receive faxes manually.
Select <Start Receiving> and press [OK]. Then, return the handset to its cradle or enter the remote receive ID. Otherwise, the call will be disconnected.
Remove the document from the feeder and receive the fax manually.
If [
] (Start) is pressed when a document is set in the feeder, the document will be sent. |
Use of the optical line is not guaranteed.
Adjust the paper guides of the paper drawer to fit the paper size.
Specify the correct paper size to load into the paper drawer.
Set <Reduce RX Size> to <On> before adjusting.
Contact the sender and verify that the resolution of the sender's machine has been set properly.
Make sure to set the telephone line type to tone dialing. If the type is set to the rotary pulse, press [
] (Tone) to switch to tone dialing. |
Follow the instructions provided from information services.
Ask the sender to check his/her fax machine.
Check the settings specified for 2-sided printing.
