NO
Make sure that the proper line type is selected.
YES
NO
Press [
] to switch to fax mode. |
YES
NO
Properly place the document.
YES
NO
Make sure that the number is properly registered.
YES
NO
Make sure that the number is correct.
YES
YES
Wait until the transmission is completed.
NO
YES
The external phone is busy. Please wait until the external phone is not busy.
NO
YES
Print the transmission management report to check for errors.
NO
NO
Make sure that the receiving fax machine is compatible with your machine (For example, check to see if the receiving fax machine is a G3 fax machine).
Make sure that there's enough paper loaded in the receiving fax machine's paper tray.
Make sure that the receiving fax machine is not busy. (If the line is busy, <Busy/No Signal> is shown in the error transmission report.)
YES
YES
Add a pause to the number and send the fax again.
Change the initial sending speed.
