You can print from a Windows Vista/7/Server 2008 computer using the WSD (Web Services on Devices) protocol.
To use WSD, follow the procedures provided in "Installing the Laser MFP Drivers" and "Setting WSD."
When you are in an IPv6 environment
You cannot install the Laser MFP Drivers from the CD-ROM setup screen.
Follow the steps in the procedure below.
To enable or disable WSD
Enable or disable WSD from the machine's operation panel. For more information, see "Selecting the Connection Method (LPD/RAW/WSD)."
When [AutoPlay] is displayed |
Click [
] to close the dialog box. |
When you are not sure which operating system that you are using on your computer |
(1)
Enter a different name to change the default printer name.
(2)
Click [Next].
When [User Account Control] appears |
Click [Yes] or [Continue].
To set the machine as a shared printer, configure the related settings after you have performed the procedure provided in "Setting WSD."
When [Set as the default printer] is displayed, specify whether to choose the machine as the default printer (Windows 7/Server 2008 R2).
Eject the CD-ROM when the following screen appears.
Follow the steps in the procedure below to delete the icon added in Step 13, if you do not need it.
