The following lists are samples. The contents may partially differ from the lists printed by your printer.
Make sure that the printer is online.
Press [
] ( Utility) to display the [Utility Menu] menu. |
Select [PCL Utility] using [
] and [ ], and then press [OK]. |
4.
Select [Font List] using [
5.
Select [Yes] using [
] in the [Execute?] display, and then press [OK] to output the page. |
Press [
Select [PS Utility] using [
4.
Select [Configuration Page] using [
5.
Press [
4.
5.
