If You Want to Adjust Color Balance
When all the printout results appear reddish or bluish, or the color balance is not appropriate, you can correct the colors by adjusting each toner density of C (Cyan), M (Magenta), Y (Yellow), and K (Black).
The toner density can be specified in the range of "-8" to "+8" and is set to the standard density "0" before shipment.
When adjusting the toner density using the control panel, use the following procedure.
Adjusting the toner density little by little, print the defective print data from the computer, and then check the printout results. If you cannot adjust the toner density, reset the density to the default value "0", and then contact your local authorized Canon dealer.
1
Press [
Online).
The Online indicator goes off, allowing you to specify the settings on the control panel.
2
Press [
Settings).
3
Select [Quality] using [
] and [
], and then press [OK].
4
Select the toner density of the target color using [
] and [
5
Select the density using [
] and [
The toner density is lightest when "-8" is selected and densest when "+8" is selected.
