The Printed Colors Appear Different from Those Printed by Another LBP5280 Being Used at the Same Time
Perform one of the following solutions according to the cause.
<Cause 1> The default setting of the toner density of K (Black), Y (Yellow), M (Magenta), or C (Cyan) is somewhat varied.
Solution
Adjust the toner density of K (Black), Y (Yellow), M (Magenta), or C (Cyan).
Adjustment of the toner density affects all the color print jobs. Normally, use the printer with the toner density left to the default value (0).
<Cause 2> Adjustment of the toner density affects all the color print jobs. Normally, use the printer with the toner density left to the default value (0).
Solution
Replace the toner cartridge of the color for which <1G Change XXXX toner cartridge recommended.> or <1G Change XXXX toner cartridge.> is indicated with a new one.
XXXX = black, yellow, magenta, cyan
