Colored Lines and Text Appear Faded
Perform the following procedure.
<Cause 1>Thin lines or text was printed.
Solution
Perform the following procedure in the printer driver.
Display the [Finishing] sheet.
Click [Advanced Settings].
Set [Special Fine Line Processing] to [Mode 1].
If the problem still persists, set it to [Mode 2].
When [Special Fine Line Process] is set to [Mode 2], text may be collapsed when printing multiple pages on one sheet (N in 1 printing). Also, the printed result may differ from the display in gradation.
<Cause 2> The toner cartridges have reached the end of their life.
Solution
Check the toner cartridges status and replace the toner cartridges of the colors have reached the end of their life.
