Solution
Load the paper properly.
Solution
Replace the paper with new paper in an unopened package.
Solution
Replace the paper with that which can be used with this printer.
Solution
Remove the foreign object inside the printer.
Solution 1
Perform the following procedure in the printer driver.
Solution 2
Select [Curl Correction] under [Special Print Mode] set it to [On] and print again.
