Number of security policies that can be registered
You can register up to 10.
If you cannot register one, delete unnecessary security policies. |
If the check box is cleared, the security policy cannot be used.
Transmission
Packets Applying the Security Policy
[Local Address]
RX
Packets with "destination IP addresses" that match IP addresses specified here
TX
Packets with "departure IP addresses" that match IP addresses specified here
[Remote Address]
RX
TX
IP Address Entry Example
IP Address Entry Method
192.168.0.1-192.168.0.10
fe80::1000-fe80::2000 |
If you want to enter the IP addresses of consecutive numbers, place "-" (hyphen) between the address of the smallest number and that of the largest number.
192.168.0.0/16
fe80::0000/64 |
In order to specify the subnet range (prefix length), enter a "/" (slash) after the normal IP address symbol, then enter another prefix length (maximum 32 for IPv4 and maximum 128 for IPv6).
Transmission
[Local Port]
RX
Packets with "destination ports" that match IP addresses specified here
TX
Packets with "departure ports" that match IP addresses specified here
[Remote Port]
RX
TX
(1)
Select the [Single Port] check box.
(2)
Enter the port number (0 to 65535).
(1)
Select [Main] or [Aggressive] under [IKE Mode].
(2)
Select [AUTH Method].
If you want to specify [Pre-Shared Key Method]
a. Select the [Pre-Shared Key Method] check box.
b. Click [Shared Key Settings...].
c. Enter the name of the shared key (up to 24 characters), and click [OK].
If you want to specify [Digital Signature Method]
a. Select the [Digital Signature Method] check box.
b. Click [Key and Certificate...].
c. Select the key to use, and then click [Default Key Settings].
[AUTH Method] Settings
In order to set [Pre-Shared Key Method], the SSL encrypted communication function must be enabled.
We recommend that network settings be performed by the network administrator.
[Authentication]
Select the authentication algorithm from [SHA1], [MD5] or [SHA1 and MD5].
[Encryption]
Select the encryption algorithm from [3DES-CBC], [AES-CBC] or [3DES-CBC and AES-CBC].
[DH Group]
Select the Diffie-Hellman group from [Group 1 (762)], [Group 2 (1024)] or [Group 14 (2048)].
(1)
When using PFS, select the [Use PFS] check box.
(2)
Set [Validity].
When specifying by time
a. Select the [Specify by Time] check box.
b. Enter the time (1 to 65535 minutes).
When specifying by size
a. Select the [Specify by Size] check box.
b. Enter the size (1 to 65535 MB).
About PFS
If PFS is used, the key generation process becomes complex. Even assuming one key is deciphered, it does not mean that later keys will be deciphered easily.
(1)
Select the [ESP] check box.
(2)
Select the authentication algorithm from [SHA1], [MD5], [SHA1 and MD5] or [NULL] under [ESP Authentication].
(3)
Select the encryption algorithm from [3DES-CBC], [AES-CBC], [3DES-CBC and AES-CBC] or [NULL] under [ESP Encryption].
(1)
Select the [AH] check box.
(2)
Select the authentication algorithm from [SHA1], [MD5] or [SHA1 and MD5] under [AH Authentication].
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
