[IPv4 Address: TX Filter]
It limits the sending of data from the printer.
[IPv4 Address: RX Filter]
It limits the sending of data to the printer.
(1)
Enter the IP address for which you want to reject or permit to print.
(2)
Click [Add].
Input example of
the IP addresses |
Method for entering IP addresses
192.168.0.1-192.168.0.10
If you want to enter the IP addresses of consecutive numbers, place "-" (hyphen) between the address of the smallest number and that of the largest number.
192.168.0.0/16
In order to specify the subnet range (prefix length), enter a "/" (slash) after the normal IP address symbol, then enter another prefix length (maximum 32).
When "0" is entered in [Prefix Length]
All the IP addresses become the target for rejection or permission.
When "32" is entered in [Prefix Length]
The IP address of the printer becomes the target for rejection or permission.
When deleting a set IP address
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
[IPv6 Address: TX Filter]
[IPv6 Address: RX Filter]
(1)
(2)
Click [Add].
Input example of
the IP addresses |
fe80::0000/64
In order to specify the subnet range (prefix length), enter a "/" (slash) after the normal IP address symbol, then enter another prefix length (maximum 128).
When "128" is entered in [Prefix Length]
