Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
About the icons
Setting Item
Setting Value
Setting
[Paper Source]
[Auto], [Drawer 1], [Drawer 2]*, [Multi-Purpose Tray]
Select the default paper source that is used when printing.
[MP Tray Paper Size]
[A5], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [Custom Size], [Custom Size R], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Env. ISO-B5], [Index Card], [STMT], [FLSC]
Specifies the size of the paper loaded in the multi-purpose tray.
[MP Tray Priority]
[Off], [On]
Specifies whether the printer should detect the paper source in order starting with the multi-purpose tray when [Paper Source] is set to [Auto] in "[Select Feeder] Menu."
[Drawer 1 Size]/[Drawer 2 Size]*
[A5], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [Custom Size], [Custom Size R], [Env. ISO-C5], [Env. No.10], [Env. DL], [Env. ISO-B5], [STMT], [FLSC]
Specifies the size of the paper loaded in the paper drawer.
[Standard Paper Size]
[A5], [B5], [A4], [LTR], [LGL], [EXEC], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Env. ISO-B5], [Index Card], [STMT], [FLSC]
If you cannot specify the paper size or if you print from DOS, UNIX, or other operating system, specify the paper size in this item.
[Diff. Paper Tray]
[Off], [On]
Specifies whether the printer should feed paper from the multi-purpose tray when paper of the size for the received data is not loaded in the paper drawer.
[Auto Selection]
[Multi-Purpose Tray]: [Off], [On]
[Drawer 1]: [Off], [On]
[Drawer 2]*: [Off], [On]
Specifies the paper source to be automatically selected when [Paper Source] is set to [Auto] in "[Select Feeder] Menu."
If [On] is specified, the printer selects the paper source as the one to be automatically selected.
[Default Paper Type]
[Plain], [Plain L], [Plain L2], [Heavy 1], [Heavy 2], [Heavy 3], [Transparency], [Envelope], [Envelope H], [Coated 1], [Coated 2], [Coated 3], [Coated 4], [Labels]
If you cannot specify the paper type or if you print from DOS, UNIX, or other operating system, specify the paper type in this item.
[MP Tray Paper Type]
[Plain], [Plain L], [Plain L2], [Heavy 1], [Heavy 2], [Heavy 3], [Transparency], [Envelope], [Envelope H], [Coated 1], [Coated 2], [Coated 3], [Coated 4], [Labels], [Mixed Types]
Set the type of paper that is loaded in the multi-purpose tray.
[Drawer 1 Type]/[Drawer 2 Type]*
[Plain], [Plain L], [Plain L2], [Heavy 1], [Heavy 2], [Heavy 3], [Envelope], [Envelope H], [Coated 1], [Coated 2], [Coated 3], [Coated 4], [Labels], [Mixed Types]
Set the type of paper that is loaded in the paper drawer.
[Manual 2-Sided (MP)]
[1st Side], [2nd Side]
Set the printing side of the paper that is loaded in the multi-purpose tray manually for 2-sided printing.
When it is set to [1st Side], it is printed on the front of the paper (the side that is first be printed).
When it is set to [2nd Side], it is printed on the back of the paper (the reverse side of the paper that has already been printed).
[2-Sided Printing]
[Off], [On]
Specifies whether the printer should print on one side or both sides of the paper.
