About the initial setting screen
The initial setting screen is displayed only when the printer is turned ON for the first time.
The indicators and display on the control panel come on, and the printer initiates a self-diagnostic test on the printer unit and optional accessories.
(Ready) indicator (green),
(Online) indicator (green) and Paper Source indicator (green) come on, <Ready to print.> appears in the display, and the printer is ready to print.
Do not turn the printer ON immediately after turning it OFF.
If you want to cycle the power of the printer, wait at least 10 seconds before turning it ON again.
If the printer does not operate properly
If an error message appears in the display on the control panel
When turning ON the printer for the first time after installing the printer and paper feeder
Do not load paper in the drawer.
Precautions when turning OFF the printer
If you turn the printer OFF, all print data remaining in the printer memory will be erased.
Power consumption when the power is OFF
Even if the power of the printer is turned OFF, power is consumed only slightly while the power plug is inserted in the AC power outlet.
To cut the power consumption completely, unplug the power plug from the AC power outlet.
] and [
], and then press [OK].
The following screen appears, and the settings are completed.
About the clock in this printer
The clock in the printer should be accurate within ± 60 seconds per month. Adjust the clock periodically.
When setting time zones and daylight savings time
