This section describes the procedure for when Terminal supplied with Mac OS X as standard is used.
If the [FTP Settings] check box is not selected in the [TCP/IP Settings] page in [Settings/Registration] - [Preferences] - [Network], settings cannot be specified from the FTP client.
1
Enter "ftp the IP address of the printer", then press the [return] key on your keyboard.
Input Example: "ftp 192.168.0.215"
If you are not sure about the IP address of the printer
Print and confirm Network Status Print while referring to " Checking the Printer Settings", or consult your network administrator.
2
Enter "root" as the user name, then press the [return] key on your keyboard.
3
Enter the administrator password, then press the [return] key on your keyboard.
The default password is "7654321".
4
Enter "cd config", then press the [return] key on your keyboard.
5
Enter "get CONFIG <the file name>", and then press [return] on your keyboard.
Enter "CONFIG" as all upper case characters.
The config file is downloaded. The characters entered for <the file name> become the name of the downloaded config file.
If the config file cannot be found
Search for the config file using the file search function of your operating system.
(The download directory for the config file varies depending on the operating system or settings.)
6
Edit the downloaded config file in "TextEdit" or a similar text editor.
For details on descriptions of each option, see "
Setting Items."
7
Enter "put <the file name> CONFIG", and then press [return] on your keyboard.
The edited config file uploads.
In <the file name>, enter the name of the config file that was entered when the file was downloaded.
8
Enter "get reset", then press the [return] key on your keyboard.
When the printer is restarted the settings will be enabled.
After checking that the printer has restarted, press the [c] key while holding down the [Ctrl] key, and return to the ftp command prompt.
9
Enter "quit", then press the [return] key on your keyboard.
10
Enter "exit", then press the [return] key on your keyboard.
11
Select [Quit Terminal] from the [Terminal] menu.
