In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
Before configuring the protocol settings
When configuring the protocol settings for the printer using the above software, the TCP/IP protocol must be able to be used in your network environment.
Make sure that each setting option for TCP/IP is specified, the printer and computer are connected properly, and the printer is ON.
About SMB printing
You can use SMB printing only when an SD card is installed.
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
About the screenshots
This procedure is described using screenshots from Windows 7.
When the [Use SMB Server] check box is cleared
The printer is not detected on the SMB network.
[Server Name]
Enter the computer name to which the printer belongs. Up to 15 characters can be entered.
[Workgroup Name]
Enter the name of the work group to which the printer belongs. Up to 15 characters can be entered.
[Comments]
If necessary, enter comments about the printer. You can enter up to 48 characters.
[Use LM Announce]
When announcing the existence of the printer to the LAN Manager, select the [Use LM Announce] check box. When not making an announcement, clear [Use LM Announce].
Select the [Use SMB Printing] check box.
Enter the name of this printer in [Printer Name]. Up to 13 alphanumeric characters can be entered.
[WINS Server Address]
Enter the IP address of the WINS server.
[Scope ID]
Enter [Scope ID] as needed. You can enter up to 63 characters.
Set the following items when registering printers on the WINS server.
[SMB Server Name]
Enter the WINS server name set in Procedure 7.
[SMB Workgroup Name]
Enter the workgroup name set in Procedure 7.
If [Scope ID] is specified
The printer cannot communicate with the computers that have a different scope ID.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
