In order to set up TLS authentication
You need to register a key and certificate or a CA certificate used for authentication to the printer in advance.
If a Message AppearsA message will be displayed if there is anything wrong with the settings. See Steps 6 to 9, and check the settings.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
