When performing FTP printing, select the [Use FTP Print] check box.
If you are using Windows
Run Command Prompt using the following procedure.
From the [Start] menu, select [All Programs] or [Programs] → [Accessories] → [Command Prompt].
If you are using UNIX
Display the console screen.
If you are not sure about the IP address of the printerConsult your network administrator.
The default user name is "guest".
You cannot perform an anonymous login.
The default password is "7654321".
The file is printed from the printer.
When printing a file
Print the file in the binary mode.
Command Prompt closes.
