Checking the SD Card Installation
After installing an SD card, print Configuration Page to check if the module is installed properly.
Load Letter size paper.
Configuration Page is designed to be printed on Letter size paper.
Be sure to load Letter size paper when printing the Configuration Page.
1
Load Letter size paper in the multi-purpose tray or drawer.
2
Make sure that the printer is online.
If the printer is not online, press [
Online).
3
Press [
Utility).
4
Select [Configuration Page] using [
] and [
], and then press [OK].
5
Select [Yes] using [
], and then press [OK] to print Configuration Page.
How to check the installation
Check to make sure that [SD Card] under the [Control Menu] is set to [On].
If [SD Card] is not displayed, see " Removing SD Card" and remove the SD card once.
If the [SD Card] is [Off], set it to [On] using the following procedure.
(1)
Press [  ] (  Settings).
(2)
Select [Control Menu] using [  ] and [  ], and then press [OK].
(3)
Select [SD Card] using [  ] and [  ], and then press [OK].
(4)
Select [On] using [  ] and [  ], and then press [OK].
(5)
Hard reset or restart the printer.
