Store the removed packing materials.
They are required when transporting the printer for relocation or maintenance.
About the packing materials
The packing materials may be changed in form or placement, or may be added or removed without notice.
Remove the protective sheet with them.
When pulling out the sealing tape
If the sealing tape stops at midpoint, pull it out of the toner cartridge completely. If any tape remains in the toner cartridge, this may result in low print quality.
Dispose of the removed sealing tape according to local regulations.
If you cannot close the front coverMake sure that the toner cartridge tray is closed.
Do not try to forcefully close the front cover, as this may damage the machine.
Check !
Checking if the packing materials are removed
Check that the following packing materials are completely removed.
Next, perform one of the following procedures.
