Type
Desktop Page Printer
Printing System
Semiconductor laser + xerographic system
Toner fixing system
On-demand fixing system
Resolution
600 dpi
Printing speed
(Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²)) when printing Letter size paper continuously)
Black and white printing: 21 pages/minute
Color printing: 21 pages/minute
Warm up time
(Time from power on to printer ready) |
29 seconds or less
Recovery time
(Time from the sleep mode to printer ready) |
0 seconds when the printer is in Sleep Mode 1 (the Panel Off mode)
8 seconds when the printer is in Sleep Mode 2 (the Printer Sleep Mode)
9 seconds when the printer is in Sleep Mode 3 (the Deep Sleep mode)*
First print time
(When performing 1-sided printing on Letter size paper and outputting face-down)
Black and white printing: 16 seconds or less
Color printing: 16 seconds or less
Paper size
Drawer 1/Drawer 2 (Optional)
Standard sizes:
A4, B5, A5, Legal, Letter, Executive, Statement, Foolscap, Envelope DL, Envelope COM-10, Envelope ISO-C5, and Envelope ISO-B5 Custom paper sizes:
Width 4.13 to 8.50 in. (100.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)
Multi-purpose tray
Standard sizes:
A4, B5, A5, Legal, Letter, Executive, Statement, Foolscap, Index Card, Envelope DL, Envelope COM-10, Envelope ISO-C5, Envelope ISO-B5, and Envelope Monarch Custom paper sizes:
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)
Paper capacity
Drawer 1/Drawer 2 (Optional): Approx. 250 sheets
Multi-purpose tray: Approx. 50 sheets
2-sided printing
A4, B5, A5, Legal, Letter, Executive, Foolscap
Paper output
Face-down
Output capacity
Approx. 125 sheets
Noise
(Declared noise emission in accordance with ISO 9296)
LwAd (declared A-weighted sound power level (1 B = 10 dB))
During standby: 43 dB or less
During operation: 6.7 B or less
LpAm (declared A-weighted sound pressure level (bystander position))
During standby: 24 dB
During operation: 52 dB
Operating environment
(Printer unit only)
Temperature range: 50 to 86°F (10 to 30°C)
Humidity range: 20 to 80% RH (no condensation)
Power supply
120 to 127 V, 60 Hz
Power consumption (68°F (20°C))
Maximum: 1,081 W or less
Average during operation: Approx. 440 W
Average during standby: Approx. 22 W
Average during Panel Off Mode (Sleep Mode 1): Approx. 22 W
Average during Printer Sleep Mode (Sleep Mode 2): Approx. 7 W
Average during Deep Sleep Mode (Sleep Mode 3): Approx. 1 W*
When the main power switch is turned OFF: 0.1 W or less
Consumables
Toner cartridge
GPR-44 Yellow
GPR-44 Magenta
GPR-44 Cyan
GPR-44 Black
Weight
Printer unit and included parts
Printer unit (excluding the toner cartridge): Approx. 49.4 lb (22.4 kg)
Toner cartridge (each): Approx. 1.5 lb (0.7 kg)
Consumables and optional accessories
Toner cartridge (each) (Canon Genuine Cartridge): Approx. 1.5 lb (0.7 kg)
Paper Feeder Unit PF-701 (including the drawer): Approx. 8.8 lb (4 kg)
CPU
528 MHz + 264 MHz
Memory (RAM) capacity
768 MB
Host interface
USB interface:
Hi-Speed USB (1)
USB (1 front and 1 back)
Network interface:
Shared 10BASE-T/100BASE-TX/1000BASE-T (RJ-45)
Full duplex/Half duplex |
User interface
LCD:
132 x 65 dots
F-STN liquid crystal display LED indicator:
8
Operation key:
12
ROM slot
1 (Used with installed PS ROM)
SD card slot
1
Built-in control command
PCL 5c, PCL 6, PostScript 3 emulation, and UFR II
Built-in fonts
PCL:
93 Scalable fonts, 10 Bitmap fonts
PS:
136 standard fonts
Printable area
PCL 5c/PCL 6:
Data cannot be printed within a 0.167 in. (4.2 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper. ![]() UFR II/PS:
Data cannot be printed within a 0.20 in. (5 mm) (0.39 in. (10 mm) for envelopes) margin on all sides of the paper.
Network interface
Supported protocol
TCP/IP (Frame type: Ethernet II)
AppleTalk
NetWare
SMB (option)
Print application
LPD
RAW
IPP/IPPS
FTP
WSD
