If a message indicating another problem occurs at the same time as the first error message, a warning message will not be displayed.
For instructions on performing [Skip Error] from the touch panel display, see "Pausing/Resuming Print Jobs."
For instructions on canceling a print job from the touch panel display, see "Canceling a Job."
Cause
A malfunction occurred and the printer cannot operate normally.
Remedy
Restart the machine. If the message does not disappear after restarting the machine, write down the message displayed on the touch panel display and contact your local authorized Canon dealer.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
There is not enough work memory for system data processing (primarily figure processing and text processing).
Remedy
Perform [Skip Error] to continue processing. However, the output result of pages containing the relevant sections is not guaranteed.
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
Remedy
Cause
An error, such as not being able to obtain memory, occurred during initialization.
Remedy
Restart the machine and execute the job again. If this error persists, contact your local authorized Canon dealer.
Cause
PCL processing failed.
Remedy
Cause
There is not enough work memory available.
Remedy 1
After canceling the print job, perform a printer reset to free up memory, then try printing again. (Note that all print data stored in memory, such as Secure Print jobs, and all print jobs being processed are deleted.)
Remedy 2
Perform [Skip Error] to continue printing. However, the data that is the source of the error will not be printed correctly.
Cause
There is not enough memory for downloading.
Remedy 1
Remedy 2
Cause
The TIFF or JPEG data contains data that cannot be processed by this machine.
Remedy
After canceling the print job, perform a printer reset, then try printing again. (Note that all received data in the machine's memory is deleted.)
Cause
An error occurred during the initialization of the function.
Remedy
Cancel the job and then perform a printer reset to initialize the function again. (See "Reset Printer.") If this error persists, contact your local authorized Canon dealer.
Cause
There is data in the TIFF or JPEG images that cannot be processed by the machine.
Remedy
Cancel the job and try printing the data again.
Cause
An error occurred while processing data.
Remedy
Cause
There is not enough memory necessary to process TIFF or JPEG images.
Remedy
Cause 1
The password you entered to print the PDF file is incorrect.
Remedy
Enter the correct password from the Remote UI and print the data again.
Cause 2
The Security settings in the PDF file do not allow printing.
Remedy
Change the setting to allow printing.
Cause 3
The policy server cannot be accessed from a PDF linked to the policy server.
Remedy
Confirm whether the policy server is turned ON, and check the status of the machine, policy server, and network.
Cause
PDF data that cannot be processed by the machine was sent.
Remedy
Contact your local authorized Canon dealer.
Cause
The machine's memory space allocated for PDF is full and printing cannot proceed.
Remedy 1
After canceling the print job, optimize the PDF in Adobe Acrobat and reduce the size of the data you are going to print at one time, such as by resetting the resolution to an appropriate level, and try printing again. (See the Adobe Acrobat Help.)
Remedy 2
After canceling the print job, reduce the number of pages to print at one time by dividing the PDF data you are going to print in Adobe Acrobat into several files, before trying to print again. (See the Adobe Acrobat Help.)
Remedy 3
After canceling the print job, open the data in the application software and print again via the printer driver. (See the Adobe Acrobat Help.)
Cause
There is font in the PDF data that cannot be processed.
Remedy
Contact your local authorised Canon dealer.
Cause
The range of the specified print pages is incorrect.
Remedy
After canceling the print job, check the number of pages in the PDF data, then specify the correct printing range and try printing again.
This error will not be displayed if there are printable pages within the printing range you specified. For example, if a PDF data has five pages in it, and you specify a printing range from page 2 to 10, then page 2 to 5 will be printed without an error being displayed.
Cause
An error occurred while processing data in UFR II custom mode.
Remedy
After canceling the print job, try printing again with a printer driver version that is compatible with the machine.
Cause
The machine received data from an incompatible UFR II version.
Remedy 1
Install a UFR II printer driver for use with this machine and print the data again.
Remedy 2
Perform [Skip Error] and continue printing. However, the data will not be printed correctly.
Cause
The work memory for the UFR II mode is full.
Remedy 1
After canceling the print job, reset the printer to increase the amount of available memory and print again. (Note that print data in memory such as secure print jobs and any jobs being processed will be deleted.) (See "Reset Printer.")
Remedy 2
If you set [Auto Error Skip] to 'On', this error is skipped automatically. (See "Auto Error Skip.")
Cause
Remedy
Cause
Remedy
Cause
Remedy 1
Remedy 2
