[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
For all selections within this setting, if the data is too large to be stored in the machine's memory, it will be recompressed at a high compression ratio.
To avoid deterioration in image quality resulting from repeated recompression, select [Display Error] for "Compressed Image Output." This allows you to cancel a job before an image with deterioration is printed out.
Depending on the image data, the image quality may not change even if the compression method is changed.
[Trapping]
[On], [Off]*
[Trapping Width]
[Upper]
0 to 3; 1* pixel
[Lower]
0 to 3; 1* pixel
[Left]
0 to 3; 1* pixel
[Right]
0 to 3; 1* pixel
[Trapping Density]
[Cyan]
0 to 100; 100* %
[Magenta]
0 to 100; 100* %
[Yellow]
0 to 100; 100* %
You cannot use this function in combination with 'Width Adjustment'.
The internal restriction value cannot be changed.
This setting can only be applied to jobs in the PS mode and PDF mode.
If [Grad. Priority] is selected, characters and lines may bleed.
If [Text Priority] is selected, the color may not match.
This setting can only be applied to jobs in the UFR II mode, PCL6 mode, PS mode, and PDF mode.
[Width Adjustment]
[On], [Off]*
[Horizontal]
[Off], [Level 1]*, [Level 2]
[Vertical]
[Target Color]
[All]*, [Black Only]
You cannot use this function in combination with 'Trapping'.
"Horizontal", "Vertical", and "Target Color" can only be selected when [On] is selected for 'Width Adjustment'.
This setting allows you to apply smoothing to graphics data and text data. Smoothing is not applied to image data.
The setting for 'Apply to Text' is invalid if 'Resolution' is set to [1200 dpi].
"Apply to Graphics" and "Apply to Text" can only be selected when [Level 1] or [Level 2] is selected for Advanced Smoothing.
Settings for "Apply to Graphics" and "Apply to Text" on the touch panel display will be effective only if 'Printer Default' is set for Advanced Smoothing in the printer driver.
The results of Advanced Smoothing may differ depending on the characters and graphics patterns.
This setting does not apply to text data.
If [Level 1] or [Level 2] is selected, and gradation is applied to halftones, graphics and images may appear grainy.
"Apply to Graphics" and "Apply to Images" are only displayed when [Level 1] or [Level 2] is selected.
