Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
For more information on the available paper for each paper sources, see "Available Paper Stock."
For more information on how to load paper, see "Loading Paper."
(Settings/Registration).
: Stack Bypass-B1 |
: Upper Paper Drawer |
: Middle Paper Drawer |
: Lower Paper Drawer |
: POD Deck Lite-B1 |
: Upper Paper Deck of the Multi-drawer Paper Deck-B1 |
: Middle Paper deck of the Multi-drawer Paper Deck-B1 |
: Lower Paper Deck of the Multi-drawer Paper Deck-B1 |
If the displayed paper size is different from the loaded paper size, paper may not be loaded properly. For more information on loading paper, see "Loading Paper."
If [Custom] is displayed as the paper size when you load standard sized paper, press [Custom Size] → [Cancel Settings]. The proper paper size will be detected automatically and displayed on the screen.
You can select a button ([S1] to [S5]) containing a stored paper size setting, instead of entering values.
If the envelope type is not set correctly, a paper jam will occur.
Simple Settings Screen
Detailed Settings Screen
You can register paper types if paper types for the loaded paper are not displayed on the detailed setting list. For instructions on registering paper types, see "Overview of This Function."
While you are registering the custom paper type for a paper source, the paper type settings are protected and you cannot change the detailed information for custom paper type or delete the custom paper type in [Paper Type Management Settings] in [Preferences] (Settings/Registration).
You can also specify the paper type from the Status Monitor/Cancel screen. (See "Checking the Status of Consumables and Other Information.")
