Configuring Accessibility Settings (Personal Settings)
Individual users can customize the operation settings to improve accessibility. For example, users can set the language and keyboard layout on the touch panel display, or the response speed when keys are pressed repeatedly. Because these settings are only enabled when the user who configured the settings log in, they do not affect the settings of other users.
To use personal settings, you need to log in with personal authentication management. Managing Users
Available settings
The settings listed below can be configured.
The language used on the touch panel display
Accessibility functions for users who have difficulty seeing or performing input operations on the touch panel display
1
Press <Personal Settings> on the Main Menu.
2
Press the setting button that you want to configure.
To set the displayed language
Press <Switch Language/Keyboard>, select a language from the list, and press <OK>.
To set accessibility
Press <Accessibility>, and select the setting you want to configure.
Press <Key Repetition Settings> to change the speed at which the same character is entered repeatedly when a button is held down. This setting may prevent users from inadvertently entering the same character more than once when performing input operations slowly.
Press <Reversed Display (Color)>
<On>
<OK> to invert the screen colors and make text easier to read.
Press <Enable Screen Magnification>
<On>
<OK> to enable you to zoom in or out on some screens by pinching out or in.
NOTE:
When the optional Voice Operation Kit(
System Options) is installed, <Voice Navigation Settings> is displayed. By pressing <Voice Navigation Settings>, you can configure detailed settings for <Manual Mode>, which audibly explains screen operations, and <Vocal Mode>, which performs operations by recognizing the user's voice.
Set the screen that is displayed when the machine starts
If the machine is configured so that users are required to log in when it starts up ( Logging into the Machine), <Default Screen after Startup/Restoration> is displayed as an item in <Personal Settings>. The screen that is displayed after the machine starts up can be set for each user.
LINKS
