Automatically Selecting the Paper Source Depending on Function
Paper sources for which Paper Drawer Auto Selection is set to <On> are used for Automatic Paper Selection and Auto Drawer Switching. You can set which paper sources can be used for Automatic Paper Selection and Auto Drawer Switching by each function, such as Copy and Print.
Automatic Paper Selection (APS): The machine automatically selects the appropriate paper size (paper source) when you start copying/printing.
Auto Drawer Switching (ADS): If the selected paper source runs out of paper during a copy/print job, the machine automatically selects another paper source with the same paper size, and continues copying/printing.
1
Press .
2
Press <Function Settings>  <Common>  <Paper Feed Settings>  <Paper Drawer Auto Selection On/Off>.
3
Select the desired function, press <On> for each paper source <OK>.
Press <Off> if you do not want to automatically select the paper source.
<Other> enables you to set the paper source used when outputting reports.
If you select <Copy>, you can set whether to consider the paper type.
If you set <Consider Paper Type> to <On>:
Paper is not fed from another paper source when the original paper source runs out of paper, unless another paper source is loaded with paper of the same size and type.
If you set <Consider Paper Type> to <Off>:
Paper is fed from another paper source when paper in the current paper source runs out, as long as the same paper size is loaded in that paper source.
If you select <Printer>, you can set whether to group paper sources.
If you set <Use Group> to <On>:
Paper sources are set as a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is performed in the group.
If you set <Use Group> to <Off>:
Paper sources are not set as a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is not performed.
4
Press <OK>.
13WR-02K
