Character input field
<Backspace> button
) to move the cursor.
on the control panel if you want to delete all the characters you entered.
Entry mode button|
<Alphanum. Char.>
Alphanumeric character entry mode
<Symbol>
Symbol entry mode
Character input button
Enter button
<Space> button
<Caps> button
<Shift> button
Cursor button|
When displaying the numeric keys iconWhen <
You can use numeric keys.> is displayed, you can enter numerical values using the numeric keys on the control panel.Example: <Copy Ratio> setting screen ![]() When <
Enter using the numeric keys.> is displayed, only the numeric keys on the control panel can be used for entering numbers.Enter characters from the USB keyboardTo enter characters, you can also use a USB keyboard by connecting it to the USB port (Front Side). Note the following points when entering from a USB keyboard.
Set <Use MEAP Driver for USB Input Device> in <USB Settings> to <Off>. <Use MEAP Driver for USB Input Device>
You can only enter ASCII characters from a USB keyboard.
Keys that are not displayed on the keyboard screen of the touch panel display, such as Delete, End, Tab, Esc, and function keys, cannot be used on a USB keyboard.
The entering sound of a USB keyboard is produced based on the <Entry Tone> and <Invalid Entry Tone> settings on the sound setting screen. Setting the Confirmation Sound and Warning Sound
