Managing MEAP Application Licenses
License file operation may be required at times other than installing a MEAP application. For example, even when the counter value or validity license is exceeded or has expired, you can continue to use the MEAP application by adding a license file. In addition, if you want to delete a MEAP application, you are required to delete the license file in advance.
1
Log in to the Remote UI. Starting the Remote UI
2
Click [Service Management Service] on the portal page.
3
Click [MEAP Application Management], and click the application to manage the license.
4
Click [License Management] to perform the intended operation.
Adding a license file
1
Click [Browse...], select the license file to install, and click [OK].
2
Click [Install]  [Yes].
Installation starts.
NOTE:
Depending on the MEAP application, you may need to restart (stop and start) the application. Managing MEAP Applications
Saving the license file on a computer
You can save a backup file on your computer before deleting the license file. If you want to save, you are required to disable the license file in advance.
Deleting the license file
Before deleting the license file, you are required to disable the license file in advance.
13WR-0LE
