Software (operating system):
Windows Server 2003 SP2*1/Windows Server 2003 R2 SP2*1/Windows Server 2008 SP2*1/Windows Server 2008 R2 SP1/Windows Server 2012*2/Windows Server 2012 R2*2
*1 64-bit operating systems are not supported.
*2 Users cannot log in with Active Directory authentication if Kerberos armoring is enabled for KDCrelated policies (group policies). Make sure to disable Kerberos armoring.
The current version of User Authentication supports 128-bit AES (Advanced Encryption Standard) authentication and DES (Data Encryption Standard) as Kerberos encryption methods for the Active Directory authentication. The encryption method that is used is automatically selected depending on the Active Directory settings. When both of these methods are available, AES is used.
When using Windows Server 2003 SP2/R2 SP2 as an Active Directory server, you can only use IPv4 as a communication protocol (IPv6 cannot be used).
To communicate with a DNS server:
port number 53
To communicate with a KDC (Key Distribution Center):
port number 88
To communicate with a server for LDAP directory service (can be changed to an arbitrary port number for the LDAP service):
port number 389
*1 The above port numbers are default values. These numbers may vary depending on the selected settings.
Software:
eDirectory V8.8 SP7 for Windows and later
Domino V8.5 for Windows and later
Operating system:
Requirements are pursuant to the product specifications of the LDAP server.
To communicate with the LDAP server using LDAP (when TLS is enabled):
port number 636
To communicate with the LDAP server using LDAP (when TLS is disabled):
port number 389
*1 The port numbers can be changed according to the LDAP server settings.
Supported operating systems:
Windows 2000/XP/Vista/7, Windows Server 2003/2008
Communication protocol:
IPv4/IPv6
Ports used for IKEv1:
UDP port number 500
Applications that IPSec can be applied to:
Applications that uses TCP/UDP/ICMP/ICMPv6
Multicast and broadcast packets cannot be encrypted.
Signature algorithm:
RSA (Rivest Shamir Adleman)
Certificate format:
PKCS#12
RSA signature algorithm:
SHA-1/SHA-256/SHA-384*/SHA-512*1
RSA public-key algorithm (key length):
RSA (1024 bits/2048 bits)
Certificate format:
PKCS#12
File extension:
pfx/p12
*1 Available only when the key algorithm is 1024 bits or more.
SHA-1/SHA-256/SHA-384*1/SHA-512*1/MD2/MD5
RSA (512 bits/1024 bits/2048 bits/4096 bits)
DSA signature algorithm:
SHA-1
ECDSA signature algorithm:
SHA-1/SHA-256/SHA-384/SHA-512
ECDSA public-key algorithm (key length):
ECDSA (P256/P384/P521)
Certificate format:
PKCS#12*2
File extension:
p12/pfx
*2 Available only when installed by using the Remote UI.
SHA-1
DSA (1024 bits/2048 bits/3072 bits)
Certificate format:
X.509 DER/PEM
File extension:
cer/pem
SHA-1
Certificate format:
X.509 DER/PEM
File extension:
cer/pem
Hash:
MD4, MD5, SHA-1
HMAC:
HMAC-MD5
Common key cryptosystem:
RC2, RC4, DES
Public key cryptosystem:
RSA encryption (512 bits/1024 bits), RSA signature (512 bits/1024 bits), DSA (512 bits/1024 bits), DH (512 bits/1024 bits)
Even when <Prohibit Use of Key/Certificate with Weak Encryption> is set to <On>, the hash algorithm SHA-1, which is used for signing a root certificate, can be used.
Log Type
Description
User Authentication
Log |
This log contains information related to the authentication status of user authentication (login/logout and user authentication success/failure), the registering/changing/deleting of user information managed with User Authentication, and the management (adding/editing/deleting) of roles with the ACCESS MANAGEMENT SYSTEM.
Job Log
This log contains information related to the completion of copy/fax/scan/send/print jobs.
Mail Box Document Operation Log
This log contains information related to the operations performed on data in the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Mail Box Authentication Log
This log contains information related to the authentication status of the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Mail Box Backup Log
This log contains information related to the backup of the data in the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Advanced Box Operation Log
This log contains information related to the operations performed on file to the Advanced Box, the Network (Advanced Box of other machines), and the Memory Media.
Network Connection Log
This log contains information related to IPSec communication failures.
Machine Management Log
This log contains information related to the starting/shutting down of the machine, changes made to the settings by using the [Settings/Registration] key, changes made to the settings by using the Device Information Delivery function, and the time setting. The Machine Management Log also records changes in user information or security-related settings when the machine is inspected or repaired by your local authorized Canon dealer.
Export/Import All Log
This log contains information related to the importing/exporting of the settings by using the Export All/Import All function.
MEAP Application Management Log
This log contains information related to the installing/starting/stopping of the MEAP application and the license operation.
Registering/Updating the Software Log
This log contains information related to the manual/delivered installation of MEAP application and system options, manual/delivered update of the firmware, and the settings for the firmware delivery.
Log for Audit Log Management
This log contains information related to the exporting/deleting of logs with this function.
Security Policy Log
This log contains information related to the setting status of the security policy settings.
Group Management Log
This log contains information related to the setting status (registering/editing/deleting) of the user groups.
Setting Synchronization Log
This log contains information related to the synchronization of machine settings. Synchronizing Settings for Multiple Canon Multifunction Printers
Authentication Print Log
This log contains information and the operation history related to the forced hold print jobs.
Logs can contain up to 40,000 records. When the number of records exceeds 40,000, they are deleted, with the oldest records first.
4098
User Authentication Log
1001/8193
Job Log
8197
8199
8202
8203
Mail Box Backup Log
8200
8198
3001
8196
3101
3101/8206
8204
Security Policy Log
8205
8208
8207
Type/Version:
USB 2.0
File system:
FAT32
Partition size:
more than 32 GB (Must not be divided into multiple partitions)
Power supply:
must supply power from an external power source
