Security settings
If the wireless connection is set up by selecting a wireless router, the WEP authentication method is set to <Open System> or the WPA/WPA2 encryption method is set to <Auto> (AES-CCMP or TKIP). If you want to select <Shared Key> for WEP authentication or <AES-CCMP> for WPA/WPA2 encryption, set up the connection in <Enter Manually>. Setting Up a Connection by Specifying Detailed Settings
1
Select the wireless LAN router to use, and press <OK>.
2
Press <WEP Key> or <PSK>, and enter the network key.
3
Press <OK>.
When the configuration is complete, the screen <Connected.> will be displayed.
1
